Thread: Context menu with authorization level
    19.10.2010
    14
    Default Context menu with authorization level
    is it possible to disable the visualization of a context menu for an unauthorized user?
    I know I can lock all the elements of the context menu according the authorization level, but the menu is still visible.
    I need to avoid showing it if the user is not allowed to use it.
    Thank's,
    Fabio
    Default Re: Cnotext menu with authorization level
    Hi Fabio,
    This is not directly possible. The context menu is linked and will therefore be called from the button.
    As you mentioned yourself, it is possible to set an authorization level for the context menu entries. You can also link an interlocking at menu entries as well.
    You can display graphics / bitmaps at the menu entry indiating that the user does not have sufficient rights or an interlocking is active. Perhaps this is a solution?
    Another possibility would be to place a button on top of the button with the context menu, that is identical except for the context menu link, and set this button invisible when the user with authorization logs in. (the normal user has the normal button on top, for the priviliged user the top button is invisible and the button below with the context menu can be operated)
    19.10.2010
    14
    Thank you for the suggestions!
    The last one should work fine for my needs.
    Fabio
  1. How can I put the authorization level on zenOn editor?
    By michael_k in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 19th January 2022, 16:13
  2. Authorization level
    By davide.galigani in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 5th February 2019, 09:43
  3. multiple Commands in one context menu
    By marchelo in forum zenon Energy Edition
    Last Post: 24th October 2013, 09:03
  4. Replies: 4
    Last Post: 22nd June 2012, 08:27
  5. Main Menu VS Context Menu
    By whitetaru in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 6th July 2011, 07:20
