Thread: Extended trend with opc-variable
    25.04.2011
    7
    Default Extended trend with opc-variable
    I try to use extended trend with archive. First, I set up the archive. The archive contains one variable from the opc-driver (opc-variable name: @PBuilding.@SLocations.@DF10_Vent.@OHwInput12.@Nnv oTemp4_val.@FSNVT_temp#SI).
    If I use this variable then the extended trend does not show anything. But if I bind with allocations the opc-variable to the internal variable (internal variable name: Temp4) and add the internal variable to the archive, the extended trend will show the curve of Temp4.
    And I have a question: can I change the long opc-variable name for a short without using the internal variable and allocations?
    18.07.2011
    138
    Default AW: Extended trend with opc-variable
    Hi robcha.
    Well that's strange. Have you already tried to check on that archive using an archive revision screen? If you open the archive with this screen to you see any entries in the list?
    Well, do you use the classic OPC driver or the OPC UA Driver?
    25.04.2011
    7
    Default Re: AW: Extended trend with opc-variable
    I checked the record opc-variable using archive revision screen. OPC-variable value is written to the archive according to the settings. I use OPC Client V2-0 driver.
  1. Extended Trend parameters
    By fabio79 in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 5th September 2012, 13:41
  2. Print data from extended trend and reportgenerator in one report
    By gralex in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 24th August 2011, 08:22
  3. Extended Trend HD Depth
    By shikra in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 10th May 2011, 23:36
  4. Extended trend module question
    By peterg in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 4th August 2009, 23:58
