Thread: RtFunction substitution, symbol's elements access
    02.04.2012
    5
    Default RtFunction substitution, symbol's elements access
    I have problem with getting full list of variables used in screen which is substituted. So far, only solution, which I have found, is extraction of variable's names using "ItemVariable" method. It would be quite good solution, but when screen contains LinkedSymbol I need access to symbol in library. Does anybody know how get access to the elements of symbol in project library or maybe I do it wrong. Please help me.
    Default Re: RtFunction substitution, symbol's elements access
    Could you tell a bit more what you try to achieve, and why?
    Is this in the runtime, or in the editor?
    Linked symbols no longer exist in the runtime.
    02.04.2012
    5
    I want create "screen switch" function with substitution of all variables and functions used in pointerd screen. This is in the editor.
    You would normally use smart naming of functions and variables in order to be able to replace them with substitution using a single string. (e.g. Motor1* with Motor2).
    With linked symbols you don't necessarily need to link variables at the symbol itself. You can use e.g. "speed" as a placeholder for the variable at an element in the linked symbol where no variable for "speed" exists in the project, and use the symbol name "Motor1" to link the variable "Motor1.speed" to this instance of the linked symbol in the screen.
    Or you use the more common linking rules to replace the variable "Motor1.speed" at the instance of the linked symbol in the screen with "Motor2.speed".
  1. How to access linked symbol sub elements
    By carlo.chiari in forum VBA
    Last Post: 1st October 2012, 14:03
  2. RtFunction - DynProperties - PictSwitch.SubstiVar
    By markus.stetschnig in forum VBA
    Last Post: 13th June 2012, 13:02
  3. Use variable in Substitution.
    By jnkpanchal008 in forum zenon Supervisor
    Last Post: 6th February 2012, 11:02
  4. How to create a rtfunction with vb
    By gozzi in forum VBA
    Last Post: 8th March 2011, 11:19
  5. Substitution von statischen Text
    By terrerg in forum zenon Supervisor
    Last Post: 29th December 2010, 09:41
