Page 2 of 2 FirstFirst 1 2
Showing results 11 to 13 of 13
Thread: OPC Client configuration
  1. #11
    27.10.2011
    Verona
    29
    Default Re: OPC Client configuration
    I add another information:
    if I try a
    Code:
    snmpwalk -Os -c public -v2c 123.123.123.123
    on the device it responds with all mib presents.
    Thank you again
  2. #12
    Hi Luca,
    You could check with wireshark to see what the difference is.
    With a "walk" usually a SNMP client sends "GET" and "GETNEXT", until it received the last oid from the MIB on the SNMP agent, this is also what our driver does, however you can also limit the amount of "GET" it will send, in the browse of the SNMP agent.
  3. #13
    27.10.2011
    Verona
    29
    Hi Mark,
    is it possible that the interrogation made by the driver is in V1? it seem that (watching on the device). That device support only V2C and doesn't answer on a V1 snmpwalk.
    Could this be the problem? Is there any way to force Zenon driver to use V2C of SNMP?
  1. Import OPC Client von Strukturdaten
    By jusufs in forum Drivers
    Last Post: 17th February 2012, 09:12
  2. facePlate configuration
    By ansab.tp in forum zenon Service Engine Supervisor
    Last Post: 25th January 2012, 00:47
  3. Structure varible using OPC Client V2-0
    By bsneddon in forum Drivers
    Last Post: 21st April 2011, 23:49
  4. Server & Client monitor configuration
    By roberto1978 in forum zenon Network
    Last Post: 10th January 2011, 23:19
  5. OPC Client driver in synchronous mode
    By micko in forum Drivers
    Last Post: 22nd November 2010, 23:27
