Thread: DNP Analog Inputs
    Default DNP Analog Inputs
    I have DNP driver and it is communicating properly with the devices .
    But am not getting the fractional values for Analog inputs (real) from the slave. Even i configured the number of decimal points as 2.
    TIA
    Default Re: DNP Analog Inputs
    Most likely your DNP3 slave isn't sending the analog inputs with a variation that contains the fractional values!
    In your DNP3 slave you can normally configure a variation for each DNP object group. For analog inputs / analog input events depending on the variation you can receive e.g. an integer value, or an integer with timestamp, or a float value.
    Consult the manual of your DNP3 slave, or the device profile, which variations are supported and how you need to configure which default variation is used.
  1. DNP commands
    By ansab.tp in forum zenon Energy Edition
    Last Post: 28th September 2012, 11:31
  2. dnp process gateway- Multiple DNP Master
    Last Post: 25th August 2010, 06:50
  3. Analog Values with GE Relays
    By janlyndon in forum zenon Supervisor
    Last Post: 16th May 2010, 22:54
  4. DNP- Process Gateway
  5. is the REMA editable in RT?(analog type)
    Last Post: 18th November 2009, 23:14
