Thread: Change user in global project
    29.02.2008
    40
    Default Change user in global project
    I want to create an interface where Zenon administrator can change user passwords in runtime. Zenon function "Change user" opens an emty user list. This is an integration project and users are deefined in a global project, this is probably the reason for the empty list.
    How is possible to reach the user list in a global project by function Change user or otherwise?
    Best regards!
    Jurij.
    Default Re: Change user in global project
    Hi Jurij,
    The users from the global project can be logged in during runtime, however they cannot be changed during runtime. (see also the online help, Chapter "Global project" - Manual -> Project and workspace -> Global project)
    One alternative would be to use the same users in all projects (xml export / xml import) and manage the password change in the runtime globally. Another possibility may be to use active directory users. Or users from an AD/LDS / ADAM source, which can be configured fairly quickly.
    11.06.2019
    is in zenOn 7.60 now a functionality that i can create/change oder delete a user in the runtime at a Main Projekt and in the subprojekts will be done the same?
    BR
    Daniel
    07.08.2018
    10
    Hai Daniel,
    Please note that users from the global project are
    read-only and do not appear in the "edit users" function
    (See the help on the global project).
    For login purposes you can still use the user
    defined in the global project but it ist not shown in the 'change user'
    function.
    King regards,
  1. Change Language with user login
    By affoltep in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 12th January 2021, 09:08
  2. Replies: 12
    Last Post: 25th November 2010, 10:54
  3. how can be save the project that consist of the sub project?
    By michael_k in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 6th March 2010, 12:31
  4. Global search and replace
    By mattsd in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 26th November 2008, 08:29
  5. How to evaluate the user level a user has in the runtime?
    By markclemens in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 6th November 2007, 17:10
