Thread: WPF Usercontrol & .Net Framework Version
    12.12.2011
    20
    Idee WPF Usercontrol & .Net Framework Version
    I would like to create WPF custom controls. Which .Net framework version is supported? Is it possible to import other libraries?
    regards
    Stefan
    Default Re: WPF Usercontrol & .Net Framework Version
    Hi stefan.maus,
    Yes, you can also use custom controls. (WPF user control library project type) You need to set the target framework to .NET 3.5. You can also import and use other libraries.
    For a WPF user control library you need to modify your XAML file accordingly and add the namespace of your user controls and references to the classes.
    See the online help in the chapter Screens -> Elements for more information, e.g. where to insert your XAML file and your compiled custom assemblies into the project, or contact your local support for more information!
  1. WPF-Element konfigurieren
    By observer1 in forum VSTA
    Last Post: 20th July 2011, 12:53
  2. Can't repeat WPF#1 blog examlpe
    By stolyarov_as in forum VBA
    Last Post: 15th July 2011, 12:48
  3. Advantage of ZenOn Energy version versus Standard version?
    Last Post: 23rd June 2011, 23:54
  4. Replies: 1
    Last Post: 20th February 2011, 23:31
  5. WPF questions
    By zenmyway in forum VSTA
    Last Post: 28th November 2010, 23:57
