Page 2 of 2 FirstFirst 1 2
Showing results 11 to 14 of 14
Thread: IEC 103 Distrubance Record
  1. #11
    Default Re: IEC 103 Distrubance Record
    Quote Originally Posted by ursulap View Post
    You can copy/move received disturbance files into another directory (and/or rename). From zenon you can do it using zenon function from group Windows - File Operations.
    I was able to download but now when i open the fault records from comtrade viewer it doesn't show anything. I attached the files. I used Micom P141 feeder management relay. Kindly help.
    Thanks,
    Archie
  2. #12
    16.06.2011
    N/A
    43
    I try to open this file but I see "Selected file is not a COMTRADE file"
  3. #13
    Two files are there 1 is cfg and other is dat. Try open the cfg file.
    Also i opened the cfg files and i see the analogues and digital signal are not define in there. Do we really have to manually enter these in the channels or it should take them from relay?
    Thanks,
    Archie
  4. #14
    891
    Over IEC60870-103 protocol you cannot get from relay all information needed to create files in COMTRADE format from transferred disturbance data. In the protocol comes something like stream of raw data, not ready-to-use file. Thus the missing information you must configure in the driver.
  1. IEC 870-103 driver
    By mytom in forum zenon Energy Edition
    Last Post: 11th February 2019, 13:56
  2. Problem with IEC 104.
    By brada in forum zenon Energy Edition
    Last Post: 6th May 2012, 23:58
  3. IEC-Protokoll - Originator-Adresse
    By karnst in forum zenon Energy Edition
    Last Post: 24th October 2011, 12:37
  4. Simulation IEC 104 address
    By kirca in forum zenon Energy Edition
    Last Post: 1st September 2011, 23:26
  5. Replies: 3
    Last Post: 12th September 2008, 09:16
