Thread: Limit.Variable and Limit.IsVariable programmable access
    Default Limit.Variable and Limit.IsVariable programmable access
    Hello everybody!
    I try to get subj properties of Limit in my VBA code.
    I found, that I have access only to 5 properties directly and to 12 properties through DynProperties (look at picture in attachment).
    None of them are Variable and IsVariable properties.
    I use 6.51SP0 Build7.
    Is there some way to get pointed properties?
    Default Re: Limit.Variable and Limit.IsVariable programmable access
    which property do you want to change?
    You could do an XML export of the variable and check for the name of the property.
    I want to change in runtime properties that in XML file are named Variable and IsVariable.
    Flag Dynamic limit acitve and Dynamic limit variable Name.
  1. Why Dynamic Limit Text allows only 1 variable?
    By batabaha in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 1st May 2012, 23:51
  2. Dynamic limit texts with hexadecimal value
    By lew in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 9th January 2012, 00:41
  3. Programmable access to Corner points
    Last Post: 21st December 2010, 00:23
  4. Limit Text - Display ID or Name of variable
    By craigdouglas in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 9th December 2008, 15:23
  5. Edit Variable limit (Delay)
    By rloureiro in forum VBA
    Last Post: 12th September 2008, 09:25
