Page 1 of 2 1 2 LastLast
Showing results 1 to 10 of 13
Thread: Screen Switch in VBA
    24.04.2012
    17
    Daumen hoch Screen Switch in VBA
    Hi
    Is it possible to switch the screen in vb without using the screen switch function?
    if possible tell me how it is?
    thanks & rgds,
    Paruvathakumar
    Default Re: Screen Switch in VBA
    Hi Paruvathakumar,
    Welcome to the forum
    It is not possible to open a screen in the runtime through the programming interface directly, without using a screen switch function.
    Perhaps you could explain why you would like to do it this way?
    24.04.2012
    17
    HI..
    thanks for the reply..
    operator will select the page list from drop down list. based the selection value i want to open the pages.
    Regds,
    Paruvathakumar.
    tobiassedlmeier Gast
    For this you don’t need VBA. There is a function in zenon called “Screen with index”. This function opens a screen with a name containing a selected variable. It is a string variable. If the user select a picture from the listbox, you write the name in a string variable and execute this function.
    24.04.2012
    17
    Hi..
    thanks.
    1. i want to show a small screen, which has a links/buttons to show/do some other operation, on mouse over the button. if the mouse pointer is our of small screen i have to close the small screen.
    2. is it possible to access the zenon functions in VBA/VSTA.?
    3. How can i read the combined element variable name in VBA/VSTA?
    many thanks in advance,
    with Rgds,
    Paruvathakumar
    Thanks&Rgds,
    Paruvathakumar
    josefm Gast
    Quote Originally Posted by paruvathakumar View Post
    I just know, that you can use the zenon integrated functionality in property window -> VBA -> mouse events -> MouseOver (see also screenshot attached)
    there you can select a VBA macro that is executed on mouse over
    best regards
    24.04.2012
    17
    Frage Re: Screen Switch in VBA
    HI..
    I'm trying to open 4 number of Screens by using the Switch with Index.
    I'm Executing the RTfunction in VBA.
    My Program Struct is as follows:
    Set the index Variable with Screen Name (Before set the Value My function detects that the variable is in online group. else it will add it in the online grp)
    Start the RTFunction
    Set the index variable with Screen name
    i'm doing the same for all the 4 pages.
    After executing the function, Result is only 4th Screen is getting open,but not before 3 screens.
    Can any one suggest what is the cause of this problem and how to over come?
    Many thanks
    Thanks&Rgds,
    Paruvathakumar
    When you execute these steps manually in the runtime (place the index variable in a screen, modify the variable, execute the screen with index function, repeat x3) is the behaviour the same?
    If you want to open 4 screens simultaneously, you need to make sure that these screens are either each linked to their own unique frame, or open the 4 screens on different monitors.
    When you open a screen "a" that uses a frame "popup" and then open a screen "b" that also uses the frame "popup", screen "a" will be closed and screen "b" will be opened.
    24.04.2012
    17
    Hi..
    If i open the screen by manually then it is working with the same function.
    But not through the script?
    and Screen sA,sB,sC,sD all have its Own Frames like fA,fB,fC,fD
    With thanks
    Thanks&Rgds,
    Paruvathakumar
    could you please post your VBA code so I can have a look on it?
  1. Can screen-switch on different resolution machines cause errors?
    By n.bulgarini in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 20th May 2011, 17:25
  2. Function switch picture
    By yara in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 8th December 2010, 06:40
  3. Replies: 2
    Last Post: 22nd April 2010, 14:51
  4. switch to the alternate value
    By westbaaam in forum VBA
    Last Post: 29th November 2009, 23:55
  5. Replies: 1
    Last Post: 17th December 2008, 09:07
