Thread: Checking if a combi-element is locked
    ptk_mzeh Gast
    Default Checking if a combi-element is locked
    I'm trying to use interlocking to lock certain elements in my pictures.
    When locking a standard button, I can easily check its locking state with Element.Enable - which will return False if the lock is active.
    But when I lock a combi-element Element.Enable will always return True, regardless of its locking state.
    Is there any way to check during runtime if an element (especially combi-elements) is locked?
    I'm Using Zenon 7.00 SP0 Build0.
    martins Gast
    Default Re: Checking if a combi-element is locked
    hi,
    sorry, so far, there is no way to determine an interlocking of a combi-element in the runtime.
    The only way to solve that is to hardcode it - you could use the value variable that you can link with each interlocking to determine the current state of the interlocking. Depending on the value, you then execute your code.
    best regards
  1. Combi Element Test Mode Issue
    By stolyarov_as in forum zenon Service Engine Supervisor
    Last Post: 24th March 2014, 12:20
  2. Nested Structured Data Type in Combi Element
    By ansab.tp in forum zenon Service Engine Supervisor
    Last Post: 21st March 2012, 07:38
  3. Combi element mit static Text und flashing limit background
    By jusufs in forum zenon Service Engine Supervisor
  4. Combi Element
    By hoscillada in forum zenon Service Engine Supervisor
    Last Post: 16th December 2009, 22:51
  5. how can I eliminate the black color as the flashing is begined.(combi element)
    By michael_k in forum zenon Service Engine Supervisor
    Last Post: 14th December 2009, 03:23
