Showing results 1 to 7 of 7
Thread: System Information Collection Tool (SIC) [Deprecated]
    27.06.2011
    96
    Default System Information Collection Tool (SIC) [Deprecated]
    Hello everybody,
    please find attached the latest version of our System Information Collection Tool.
    If you´re facing issues with zenon and you need help from the Copa-Data support, please run the tool and attach the output file to your support request. This can help to make the investigation more efficient.
    After starting the tool you´ll find four options. In most cases "Full" scan is the best choice. When the scan is finished you can review the result yourself or save it to a zip file which you can add to your support request.
    Please keep in mind that the tool does not replace a description of your problem. So, even with the SIC file attached, always try to explain your problem as detailed as possible in your support request.
    Also mind that the SIC file contains information about your system which you might not want to share with everybody. So, please don´t upload SIC files to the forum.
    thanks,
    Alex
    PS: SIC Version 7.50 build 28986 (No longer available in this thread - Please visit the thread Off Topic > System Information Collector (SIC)).
    Default Re: System Information Collection Tool (SIC)
    Hello, alexf!
    We found your SIC useful for us too, but there is a fly in the ointment.
    When we see at console programms results, russian letters are distorted with wrong encoding...
    May be you can update SIC to handle russian encoding correctly?
    27.06.2011
    96
    Default AW: System Information Collection Tool (SIC)
    hello stolyarov_as,
    thanks for the hint. I will forward this issue. As soon as a new version is available you´ll find it here in the forum.
    best,
    Alex
    23.08.2012
    7
    Hallo alexf,
    gibt es das SIC auch für Win98SE?
    Ich habe eine Visualisierung mit Zenon 5.50SP5 auf einem Win98SE Rechner laufen und würde gerne dieses Tool ausprobieren um den Bericht an einen Support zu schicken, jedoch verlangt dieses SIC, welches ich hier heruntergeladen habe eine neuere Version von Windows.
    Schon mal Danke für die Antwort.
    josefm Gast
    Hallo tomhul,
    soweit ich weiß ist das SIC nicht mit Windows 98 kompatibel, allerdings kann ich auf die Antwort keine Garantie geben. Ich glaube nur, dass es mit dem .NET Framework zusammenhängt und deswegen nicht kompatibel ist, aber wie gesagt, alles nur Vermutungen.
    LG Josef
    880
    Das "alte" TestConnection Tool sollte hier vielleicht weiterhelfen können
    http://www.copadata.com/forums/showthread.php?t=785
    25.06.2012
    157
    Please find the new thread for the SIC tool here: https://forum.copadata.com/showthread.php?7331-System-Information-Collector-(SIC)-New-thread
    David Cerdeira
  1. Zenon Startup Tool
    By gtgallemit in forum Engineering Studio & Service Engine
    Last Post: 8th June 2012, 01:01
  2. Testconnection Tool
    By stefan_m in forum Diagnosis Tools
    Last Post: 2nd April 2012, 23:27
  3. Replies: 3
    Last Post: 26th August 2011, 08:23
  4. Information Unlimited 16 - Sample
    By robertf in forum VBA
    Last Post: 28th November 2008, 13:34
  5. when I start the editor from the startup tool nothing happens
    Last Post: 3rd January 2008, 08:51
