Thread: DynProperties("Text") of a static text
    29.02.2008
    40
    Default DynProperties("Text") of a static text
    Hello!
    Is it possible to set the DynProperties("Text") of a static text element from VBA code?
    I use following code:
    ___
    Dim KomScr As DynPicture
    Set KomScr = thisProject.DynPictures.Item("KOMANDA")
    KomScr.Elements.Item("sig_txt").DynProperties("Text") = "TEST1"
    ___
    "sig_txt" is the name of a ststic text element on screen "KOMANDA"
    But it does not function?
    What is wrang there??
    Additionaly I am trying to find out how to open a screen from VBA (screen switch)??
    Thanks and best regards!
    Jurij.
    879
    Default AW: DynProperties("Text") of a static text
    It is not possible to modify this text in the runtime.... as the name of this element already implies "Static text" element.
    What you can do is do use the element "Dynamic text" where you link a string variable (i.e. from the internal driver). Then you simply write the text via VBA to this variable.
    regards,
    herbert
    29.02.2008
    40
    Default Re: DynProperties("Text") of a static text
    Hello!
    Thanks for the answer.
    Now I am trying to set the dynamic property "Function" of a button in VBA runtime. Is this allowed? Is there somewhere in documentation seen which propertie can be set in runtime and which not?
    I would like to do the following:
    thisProject.DynPictures.Item("KOMANDA").Elements.Item("btn_OK").DynProperties("Function") = Fname
    Fname= string containing the zenon function name
    Thanks,
    BR,
    Jurij.
    879
    No, the properties of elements can not be changed in the runtime - this is only possible with functions (modify function-parameters and afterwards executing).
    When you want to execute some different actions on a button, based on a logic within VBA, do it this way:
    - link a LeftClickUp() Makro to the button
    - remove the function which is linked to this button by now
    - in the LeftClickUp() Makro you then execute the function which you want
  2. Replies: 2
  3. Replies: 3
    Last Post: 5th March 2010, 08:50
  4. Change Text Button with DynProperties
    By acko01 in forum VBA
    Last Post: 16th October 2009, 10:29
  5. Replies: 5
