Thread: Interlocking: Value not available
    25.03.2012
    21
    Default Interlocking: Value not available
    Hi all
    I have this interlocking conditions:
    (X01.Value = 1) AND (X02.Value = 5)
    I want to be able to control my device even when Value 1 is not available and have the interlocking explicitly when the Value is = 1, but I get "One or more values are not available"
    I checked the Help files and it seems to be an Internal interlocking condition.
    Can I disable or change this behavior for this Interlocking?
    Default Re: Interlocking: Value not available
    By "even when the value is not available" do you mean that there is no known value and status for this variable in the runtime?
    In this case, the runtime cannot determine the interlocking state.
    Have you tried switching the variable to alternate value?
    25.03.2012
    21
    By not available I mean:
    variable is red by a device via IEC60870-5-104 and the device is not connected in the network
    I need to bypass the interlock when the device is not available and have the interlock only when it is online and the value in the variable is the defined one.
    Stoil
    Wether there is no value, or the value is INVALID, switching to the alternate value, and setting the alternate value to the appropriate value for the interlocking to be unlocked, allows you to bypass the interlocking.
    You can switch to alternate value, through the set value dialog (combo-box), through Recipe Group Manager, through the report generator or using the programming interface.
  1. Event and interlocking in ALC
    By roberto1978 in forum zenon Energy Edition
    Last Post: 28th January 2016, 11:13
  2. ALC interlocking
    Last Post: 7th October 2009, 08:44
  3. Action buttons at the command interlocking
