Originally Posted by
markclemens
Hi Jurij,
You can try and delete all the runtime files on the webclient (from the %temp%zenwebcli directory), and try starting the webclient again.
Make sure, that the new project name is actually taken over on the server. Just renaming the project and transferring the runtime files to the server is not enough. The webclient may connect to the webserver, then the webserver tries to connect to the server, but does not find a project with that name.
Did you reload all projects on the server? Or did you restart the runtime on the server?
