Thread: Web client VBA
    29.02.2008
    40
    Default Web client VBA
    I have the folloving problem with Web clien VBA:
    I am using a VBA code that distinguishes between WEB logins and local logins - so the same user has differernt autorization level if logged over web.
    When I run the web client I get error (see attached Web_cli_VBAerr.PNG)
    The client computer does not reckognize have basic VB commands like Trim()...
    How is possible to fix this without having to install complete visual studio or similar???
    Thanks for the answer and BR,
    Jurij.
    880
    Default AW: Web client VBA
    this behaviour mostly occurs if on the computer a reference used in the VBA Code is missing
    - open the VBA Editor on the WebClient
    - check the references
    29.02.2008
    40
    Default Re: Web client VBA
    Hi, Herbert,
    One reference is really missing. It is a VBA timer control that is used in one of the VBA functions.
    Is there a way of automatic transfering the neaded files, or has to be done manualy for each computer that wants to connect to Zenon Web server?
    BR,
    Jurij.
    880
    What you can try is to put this control into the zenon file folder "Others"
    -> thus this control would be transfered also to the Clients
    -> What you still have to do is to register this control on the computer (regsvr32)
  1. Verbindungsproblem von Web-Client zu zenon-Projekt
    By markh in forum Webserver/Webclient
    Last Post: 27th September 2011, 00:17
  2. Internet Explorer 8.0 for Web-Client ?
    By lephis in forum Webserver/Webclient
    Last Post: 3rd June 2011, 06:34
  3. How does Firefox work as a Web-Client Browser?
    Last Post: 24th June 2009, 20:07
  4. Web Client 620 crashes on startup.
    By zw1 in forum Editor and Runtime Setup
    Last Post: 20th April 2009, 14:23
  5. The web client does not open the zenon project...
    By shahrzad in forum Webserver/Webclient
    Last Post: 8th October 2008, 13:32
