Thread: i can't open the demo
    08.03.2012
    29
    Default i can't open the demo
    hi,mark
    i use the zenon651.then a little day ago i have found the demo is useless.when i click a screen it can't display,then i found the frame lost.why?can i get the copy of demo?
    i need your help
    thanks
    Default Re: i can't open the demo
    In case of the demo project, the frames for each of the local projects are in the global project. If the global project is not in your workspace, the screen does not find the template and cannot be opened.
    Please check if you still have the global project in your workspace. If not, you can try and insert the global project called "COPA-DATA_GLOBAL" (right click on the workspace in the project manager, select "insert existing project")
    Alternatively, you can restore the workspace backup of the demos from the zenon DVD, (\setup\DEMOS\RT\DEMOS651.wsb) howver if you have made changes to any of the demo projects, these will be lost.
    This is also your option if you have accidentally deleted the COPA-DATA_GLOBAL project.
    I hope this helps!
    08.03.2012
    29
    Daumen hoch Re: i can't open the demo
    thanks ,mark,i get it
  1. Process Gateway module in demo license
    By michael_k in forum Drivers
    Last Post: 4th July 2017, 13:35
  2. Zenon 5.50 SP5 Demo Version Needed
    By adf_kdm in forum Editor and Runtime Setup
    Last Post: 20th August 2010, 08:07
  3. Demo on making comments (Post-It) on elements
    Last Post: 25th June 2010, 12:05
  4. Name of curretly open picture
    By scotttee in forum VBA
    Last Post: 4th January 2010, 23:58
  5. Replies: 0
