Thread: Archive start/stop notification
    Default Archive start/stop notification
    I want to be able to Notify the operator on "running" status(i.e., if archiving is stopped, it should trigger an alarm) of archiving. How can this be achieved?
    TIA
    Default Re: Archive start/stop notification
    Have a look at the archive configuration. You can execute a function (e.g. set a boolean variable TRUE) when the archive starts, and execute another function when the archive stops (e.g. set the same boolean variable FALSE). Using a reaction matrix, you can react on the change TRUE->FALSE of this boolean variable, and generate an alarm.
    By default the archive starts with the runtime, and stops when the runtime is closed.
    Its working, Thanks.
  1. Start/Stop Arvhive on PLC Trigger
    By joebloggs in forum Drivers
    Last Post: 13th February 2020, 10:10
  2. CEL 'Stop' button
    Last Post: 11th August 2009, 09:16
  3. How to Stop Logging Alarms
    Last Post: 29th September 2008, 11:24
  4. Archive SE seems very limited
    Last Post: 25th September 2008, 14:43
  5. How does the batch archive gets its name?
    By bernhards in forum zenon Pharma Edition
    Last Post: 21st August 2007, 08:59
