Thread: Changing contrast of a panel during runtime
    25.01.2012
    11
    Default Changing contrast of a panel during runtime
    Hello!
    Does anybody know how to change Contrast (make it dimmer or lighter) of a panel during runtime? The panel on which the zenon project will run is Vipa. I have not found any standard functions to do that. Is it possible and how it can be implemented?
    Default Re: Changing contrast of a panel during runtime
    I'm pretty sure that needs some kind of Vipa program to do that. (zenon cannot directly control the screen brightness).
    If this can be done with an external Vipa application, you might be able to start this program using the zenon "start program" function.
  1. Close Runtime on panel.
    By takarlsson in forum zenon Operator
    Last Post: 3rd May 2011, 01:23
  2. Copy recipe to a CE panel.
    Last Post: 5th April 2011, 13:18
  3. Keyblock Runtime - Win Control panel disappears
    Last Post: 11th October 2010, 10:23
  4. display the load changing
    Last Post: 1st February 2010, 00:35
  5. Changing systemtime
    By markusw in forum Drivers
    Last Post: 10th September 2007, 21:25
