Thread: Status bit of structured variable
    Default Status bit of structured variable
    I have created a DNP3 structured variable. I am trying to get the invalid bit status of a sub variable of the structured variable in straton using "VSIGETBIT" Function block. But the output of the block is FALSE even when there is communication error. (output is TRUE if i connect a normal variable i.e., a non structured variable). Is there any other way to get the invalid bit status of the sub variable of the structured variable?
    TIA
    Default Re: Status bit of structured variable
    VSIGETBIT is the correct function to get the read out the status bits of a variable. If this is working with a normal variable and not working with an array variable, I would contact your local COPA-DATA support to investigate this issue further.
  1. How to show alarms with status bit "Revision" in alarm list
    By softart2 in forum zenon Supervisor
    Last Post: 9th February 2012, 23:46
  2. GI Status Bit in REMA
    Last Post: 2nd January 2012, 13:06
  3. alarm status from variable
    By westbaaam in forum VBA
    Last Post: 7th October 2009, 05:43
  4. Status variable for alarm areas
    By hicom in forum zenon Supervisor
    Last Post: 24th February 2009, 09:56
  5. Change variable status
    By brada in forum VBA
    Last Post: 13th February 2008, 17:55
