Page 1 of 2 1 2 LastLast
Showing results 1 to 10 of 11
Thread: Logging into multiple projects
    29.02.2008
    40
    Frage Logging into multiple projects
    Hey,
    I'm having problem logging user into mutliple projects. In my workspace, I have a main project, witch contains a few sub-projects. I was trying to implement metods from this thread.
    When I used herbertos code, I was getting message box saying "Invalid user identification!". When I make the user in the project, it works. But...I have 10 sub-projects already (more to come) and quite a lot of users, witch makes creating user by user a bit time consuming.
    I also tried modified version of his code, witch should create new users and log them into projects. But...didnt work. Function CreateUser in VBA somehow does not want to create a new user, if it is executed via zenon runtime. CreateUser works if I run it via debug mode in VBA.
    Any help is appreciated!
    Modified code:
    Option Explicit
    Dim WithEvents myPwd As Passwords
    'event fired on starting runtime
    Private Sub Project_Active()
        'create object for "UserChange" event
        Set myPwd = thisProject.Passwords
    'event fired when a user logged in
    Private Sub myPwd_UserChange()
    Dim iProjCount As Integer
    Dim level, level1, level2, level3
    Dim zUsername, zUserIden As String
    zUsername = myPwd.loggedUser
    zUserIden = myPwd.ItemUser(zUsername).Identification
    level = myPwd.ItemUser(zUsername).level
    level1 = myPwd.ItemUser(zUsername).level1
    level2 = myPwd.ItemUser(zUsername).level2
    level3 = myPwd.ItemUser(zUsername).level3
        On Error GoTo Errorhandler
            'go through all projects
            For iProjCount = 0 To thisProject.Parent.Count - 1
                'check if this is the integration project itself (no double login)
                'MsgBox thisProject.Parent.Item(iProjCount).Name
                If StrComp(thisProject.Guid, thisProject.Parent.Item(iProjCount).Guid) <> 0 Then
                    'check if the new user is the system user (logout)
                    If myPwd.loggedUser = "0000" Then
                        thisProject.Parent.Item(iProjCount).Passwords.Logoff
                    Else
                        'first create new user
                        thisProject.Parent.Item(iProjCount).Passwords.CreateUserEx zUserIden, zUsername, "", level, level1, level2, level3
                        'log in the user (from the integration project)
                        thisProject.Parent.Item(iProjCount).Passwords.Login (zUsername)
                        'check if the login was successful
                        If thisProject.Parent.Item(iProjCount).Passwords.loggedUser <> zUsername Then
                            'user could NOT be logged in
                            'write to CEL of integration project
                            thisProject.Parent.Item(0).Cel.WriteCelString ("User: """ & zUsername & """ could not be logged into project: " & thisProject.Parent.Item(iProjCount).Name)
                        End If
                    End If
                End If
            Next iProjCount
        Exit Sub
    Errorhandler:
       'an error has occured
        If err.Number <> 0 Then
            thisProject.Parent.Item(0).Cel.WriteCelString ("There was an error while trying to log into the project: " & thisProject.Parent.Item(iProjCount).Name)
            Resume Next
        End If
    'event fired on closing runtime
        'release the created object
        Set myPwd = Nothing
    880
    Default AW: Logging into multiple projects
    if all users should be available for all projects (sub-projects) i would suggest to define those users in a global project. Thus you only have to create a new user once in the global project, compile all changed data for all projects....
    regards,
    herbert
    29.02.2008
    40
    Default Re: AW: Logging into multiple projects
    Thanks for anwser. Currently I have a few users made, all defined in global project. I have compiled and reloaded all projects correctly. But still, this code is returning me "Invalid user identification!" for all project it tries to log in.
    880
    you may check the project setting "RT changeable" data" - the checkbox for "user administration" needs to be disabled... for all projects..
    29.02.2008
    40
    Disabling didnt help, any other ideas?
    880
    you may direct contact copadata support in this case. please send in an email the workspace backup and a short description.
    regards,
    herbert
    Default Re: Logging into multiple projects
    After the suggestion from Herbert, to uncheck the checkbox for passwords in the "rt changeable data" in the column "do not compile and transfer", did you compile the runtime files for all projects, and transferred the runtime files?
    Only unchecking this option in the editor, does not change anything
    You have probably done it, but I'm just checking and trying to help
    29.02.2008
    40
    I have disabled option "do not generate and transfer" and "do not compile" by selecting the checkbox for all subprojects. I have reloaded for all projects, of course.
    Tough I am not sure if I need to transfer runtime files; the application is ment to run on one computer only.
    880
    We received the inquiry at the support and created a ticket out of it.
    One thing which I want to point out in this thread:
    in your code:
    thisProject.Parent.Item(iProjCount).Passwords.Crea teUserEx zUserIden, zUsername, "", level, level1, level2, level3
    If you define the users in the global project (so in the editor) there is no need to create the user again in VBA!
    -> so please remove this code line and give a short feedback if the login function via vba is working
    29.02.2008
    40
    No, the code isn't working, as stated in the 1st post in this thread. I am getting message box saying "Invalid user identification!", for each project your original code tries to login.
  1. how to combine three different projects
    Last Post: 29th July 2019, 08:13
  2. Return to last in 2 projects
    Last Post: 12th March 2012, 00:35
  3. Integrating Projects
    By talal.mubarak in forum zenon Supervisor
    Last Post: 6th September 2011, 23:17
  4. How to Stop Logging Alarms
    Last Post: 29th September 2008, 11:24
  5. start different projects on CE
    Last Post: 25th September 2007, 08:14
