Thread: Zenon Process Gateway on Clients
    04.09.2009
    84
    Default Zenon Process Gateway on Clients
    Hi Support,
    Just want to confirm if I can use Zenon Process Gateway and OPC Server on a Machine running Zenon Client Runtime? Or is it necessary that I need to have a connection with Server Runtime?
    Thanks.
    Default Re: Zenon Process Gateway on Clients
    Yes, you can use the zenon OPC server or the process gateway on a client. The OPC server itself connects to the local client runtime. The client runtime will then connect to the runtime server to get the updates for variable values over the network and provide these to the locally running OPC server or process gateway.
    In fact running an OPC server on a zenon runtime client, on the same PC as the OPC client, is preferred over running the OPC server on the server runtime, and trying to connect an OPC client over DCOM.
    The zenon network connection between Server and Client, is much more robust and efficient than OPC over DCOM
    04.09.2009
    84
    Oh yes, the DCOM
    Thanks for making my life easier
  1. Zenon Process Gateway Hangs
    Last Post: 7th February 2012, 13:54
  2. Process Gateway
    By murphys in forum Drivers
  3. Zenon process gateway.
    Last Post: 14th January 2010, 13:17
  4. Process gateway-DNP3
    By rolindo in forum Drivers
  5. Process Gateway
