Showing results 1 to 7 of 7
Thread: Get Command name from variable
    Idee Get Command name from variable
    Hallo!
    I try to get information about what Command is linked to variable.
    In code like
    Public Sub LeftClickDown_SdSymbol(obElem As Element)
      Dim var As Variable
      Set var = obElem.ItemVariable(0)
      Dim LockingName As String
      LockingName = var.DynProperties("LockingName")
    LockingName is always "".
    What I do wrong?
    Default Re: Get Command name from variable
    I use 6.51 Build7
    Not all Dynproperties are also available in the runtime.
    Can you tell why you would want to read out the command group linked to a variable through the leftclickup event in the runtime?
    In case of symbol variable has no linked command group i want to show my own window (for examle vba form) with alternative actions.
    OK, perhaps you can make this decision based on the variable name, or identification?
    Did you know you can define specific keyboard screens, and define at the element, which keyboard should be used?
    Perhaps it is an idea to have different symbols with combi-elements. One symbol, that you use for variables with command processing, and another symbol for other variables.
    Another idea is also to export the property for set value and for the keyboard, at the combi-element in the linked symbol, and change at the linked symbol instance where required.
    I didn't understand what do you mean with "keyboard screen"? May be it described in some pdf manual comes with zenon installation?
    Sometimes I'm also surprised what treasures of information you can find in the zenon online help
    Have a look at the properties of e.g. the combi-element, in the "set value" category. Here is the property "Screen Keyboard". When you select the property, you'll find basic information in the embedded property help, and more information, when you click the link in the embedded help, in the online help in the chapter "keyboard".
    mark
  1. DCO command variable isOnline question?
    By softart2 in forum VSTA
    Last Post: 30th June 2011, 00:22
  2. Command Control
    By yara in forum Drivers
    Last Post: 7th December 2010, 14:49
  3. command resp. return variable
    By westbaaam in forum VBA
    Last Post: 16th October 2009, 07:42
  4. command
    Last Post: 9th October 2009, 06:30
  5. vba Double Command?
    By eyup in forum VBA
    Last Post: 13th August 2009, 23:59
