Thread: Zenon Process Gateway Hangs
    04.09.2009
    84
    Default Zenon Process Gateway Hangs
    Hi Support,
    I am dealing with a Zenon Energy Edition Project having 1000 61850 Variables. The Runtime is running fine but, on exporting them via DNP3.0 using Zenon Process Gateway, the Gateway hangs up after few seconds and I have to end its Process.
    Any idea why it is happening?
    The physical resources like memory and processor speed etc are more than enough to accommodate a Project of this size. The Operating System is Windows Server 2008 and Zenon Energy Edition is 6.22 SP1
    Default Re: Zenon Process Gateway Hangs
    As this seems to be reproducible in a test environment, it is probably best to send an inquiry to your local COPA-DATA supporrt, with all relevant information, and a project backup.
    You may want to activate full logging for the zenrt32.exe process and the zenprocgateway.exe process in the diagnosis viewer, and include the logfiles from the diagnosis server of the time period where this issue was reproduced, with your support inquiry. It could also help, if you include a wireshark network sniff from the same period.
    Does this happen also when there is no DNP3 master attempting to connect to the process gateway? (e.g. with the network cable / serial cable unplugged and the 850 driver set to "simulation static")
    mark
    04.09.2009
    84
    I will definitely follow up with the local Copa Data Support if this issue prolongs further.
    For the time being, I haven't tested it with 850 driver set to 'simulation static', but I will do that once I am in that location again.
    And yes, It is happening even if there is no DNP3.0 Master attempting to collect the data from Process Gateway.
    Thanks Mark.
  1. Process Gateway
    By murphys in forum Drivers
  2. Zenon process gateway.
    Last Post: 14th January 2010, 13:17
  3. DNP- Process Gateway
  4. Process gateway-DNP3
    By rolindo in forum Drivers
  5. Process Gateway
