Thread: flashing when value change
    16.06.2011
    N/A
    43
    Default flashing when value change
    I am using combi element. Value 0 1 2 3
    I want to see flashing element when value is changed. And I want to acknowledge this flashing.
    And where I can see status of value?
    Default Re: flashing when value change
    The built-in functionality of acknowledging of flashing can be done via a double right-mouse click on the element.
    However this is the flashing attribute of the variable that is activated through a limit / reaction matrix, and not the flashing for a state at the combi-element.
    You can view most statusbits of a variable in the variable diagnosis screen. Simply create a variable diagnosis screen, create a screen switch function, make sure the column "status" is available, and add the varialbe(s) you want to monitor.
    Hope this helps!
    16.06.2011
    N/A
    43
    This element have the context menu, and when I press double right-mouse - I see the context menu. Is there another way?
    There is a zenon function "alarms: acknowledge flashing". This function however, does not acknowledges a single variable that is flashing, but a complete screen (frame), which in your case may also be helpful.
    You could implement this function in your context menu.
  1. Reset Flashing
    Last Post: 17th May 2011, 00:15
  2. Resettting Flashing of Elements
    Last Post: 22nd April 2011, 00:09
  3. Replies: 2
  4. Replies: 1
    Last Post: 14th December 2009, 03:23
  5. Replies: 0
    Last Post: 21st August 2007, 08:15
