Thread: Send command to RTU
    16.06.2011
    N/A
    43
    Default Send command to RTU
    How can I send command to RTU using IEC-870-104 protocol? Do you have any examples?
    1,033
    Default Re: Send command to RTU
    shortly: you must create a command variable (e.g. with T45 for single-command or T46 for double-command) with the COA and IOA as the RTU expects. And then you set value 0 or 1 to the variable (or better - you use zenon module Command Input to process it).
    details: what about zenon Energy training? Energy is a complex topic and the IEC60870 Standard is a sophisticated communication protocol. IMHO it is something one needs more as few questions and answers on a Forum.
    15.01.2012
    5
    Hello I wil ask some question about command input.I crated a command group and i selected this command group from variable. when i compile the project there is an error on output window the variable which i selected can not be determine .after that if I pair any reaction matrix with this variable. there is no problem. i wonder that relation of the reaction matrix and command input.maybe there is small detail
    It may depend on the version that you are using. In earlier versions a limit text for the direction was required, and this was obtained through the reaction matrix.
    In later versions you can still use the reaction matrix, but a standard direction text for ON / OFF is used when no reaction matrix is linked.
  1. Send Value to hardware
    By anahita in forum VBA
    Last Post: 7th August 2011, 22:54
  2. send file to printer
    By gralex in forum VBA
    Last Post: 23rd July 2009, 07:25
  3. Send To Hardware in 6.22
    By madphilly in forum VBA
    Last Post: 22nd September 2008, 15:06
  4. send value to hardware
    By dak2483 in forum Drivers
    Last Post: 19th September 2008, 16:33
