Thread: Please help me with settings IEC870
    16.06.2011
    N/A
    43
    Default Please help me with settings IEC870
    I want to test IEC870-104 connections with Siemens SICAM PAS. SICAM PAS is slave, ZENON-master. PAS settings contains ASDU adress and IP
    ZENON contains :
    1. Net adress
    2. IEC COA
    Where I Should paste ASDU adress from PAS? In Net Adress or COA?
    1,033
    Default Re: Please help me with settings IEC870
    Net address is a freely definable number representing for zenon the connection definition made in driver configuration. The same Net address must be specified in the variable addressing. In this way, the variable is referenced to the right connection with responding IEC 61850 Server (slave).
    COA (in the driver configuration defined by sector in "IEC") means Common addres of ASDUs in the IEC60870 Protocol. Thus, i suppose it is exactly what you mean with "ASDU adress".
    The same COA value must be specified in the variable addressing. In this way, the variable is referenced to the right sector in this connection.
    Net address = connection = device (slave)
    COA = one sector of connection = one datablock of the device
    Please note that you can online import variables from the slave - it creates variables automatically with right addressing. To do this your driver must be configured with right IP address of the slave and have definition of the slave's sectors (and the rest of communication parameters must be correct). Then in zenon Editor with the right-click on the driver you can call import from running slave.
    The online import can only create variables of monitoring direction (communicated from slave to master), not the command variables.
    16.06.2011
    N/A
    43
    thanks, I created variables through import with ABB MicroSCADA. I can substitute value from MicroSCADA now.
  1. IEC870 Doppelmeldungen
    By karnst in forum zenon Energy Edition
    Last Post: 6th September 2011, 07:17
  2. Settings for report printer
    By bojan in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 26th April 2011, 17:03
  3. Settings for the aml don't take any effect
    By matthias.zoellner in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 14th August 2008, 12:22
  4. Importing variables for the IEC870 driver is hanging
    Last Post: 10th December 2007, 13:51
