Thread: Combi Element Test Mode Issue
    Default Combi Element Test Mode Issue
    In 6.51 SP0 version of ZenOn we have noticed that in Editor for Comby Elements with Type Of Display = Symbols From Library test mode does not work.
    If we use Type of Display = Graphic file and screen symbol test mode works ok.
    In runtime both cases work ok.
    As we can remember in 6.50 both cases worked ok in Editor test mode also.
    Is this bug or we doing something wrong?
    Default Re: Combi Element Test Mode Issue
    this is an already known issue and is scheduled to be fixed.
    Currently it can not be estimated when this will be done.
    Hello, support team.
    More then two years gone but problem is still here (In 7.10 Build7700 at least).
    Is there some news about when test mode of symbol will be fixed?
    Andrey
  1. OPC Client driver in synchronous mode
    By micko in forum Drivers
    Last Post: 22nd November 2010, 23:27
  2. Replies: 2
  3. Combi Element
    Last Post: 16th December 2009, 22:51
  4. Replies: 1
    Last Post: 14th December 2009, 03:23
  5. 6.50: Changing driver mode via VBA
    By herberto in forum VBA
    Last Post: 3rd December 2009, 15:27
