Showing results 1 to 7 of 7
Thread: Can not create new project.
    18.11.2011
    12
    Default Can not create new project.
    I am having a weird problem right now. I tried to create new project but failed.
    Even after creating new workspace, I can not create new project.
    Please see attached images.
    P.S.: I compressed my C: drive after installing Zenon. Can this cause any problem?
    I re-installed several times, but no result.
    18.11.2011
    12
    Default Re: Can not create new project.
    HI,
    One more thing I just observed that, ZenDbSrv.exe is running.
    But I changed my PC name a few days ago, so due to that it is not connecting to SQL.
    So where or how can I change, PC name for this exe or Zenon_Dev instance?
    880
    for the changed computer name:
    type %cd_system% into the address bar of the explorer
    -> the zenon system folder will be opened
    -> open the file zenDb.ini
    -> check at SQL Provider string if there is your old computer name within the sting (localhost should also work)
    for the compressing issue:
    afaik the SQL project path must not be compressed
    -> btw: the installation of zenon is also not possible if the whole C:\ drive is compressed
    18.11.2011
    12
    Yes, it is localhost.
    I compressed whole drive after installing Zenon, but I can install zenon still.
    I re-installed two times. It shows drive is compressed on installation window.
    880
    so decompress the whole drive and try it again
    zenon Editor was working before.. yes?
    -> after compressing the the drive the zenon editor does not work
    --> so this is probably the reason for this
    for the SQL providersting
    -> localhost should be fine
    also register the version via the startup-tool (after decrompressing)
    18.11.2011
    12
    ok..I will try.
    Zenon still works fine, but with the already created project only. I can modify and run this project but can not create new project.
    okay.
    tobiassedlmeier Gast
    How long is your new pc name? Is it more than 15 signs?
  1. Create an Element
    By robertf in forum VBA
  2. create project
    Last Post: 31st July 2011, 10:13
  3. Replies: 12
  4. how can be save the project that consist of the sub project?
  5. can't create new project in zenon editor
