Thread: dynamically create Alarm Areas
    19.01.2011
    Default dynamically create Alarm Areas
    My goal is to write a VSTA macro that will scan the variables in a project and assign an Alarm Area to the variable based on some rules. Is there a method/object available in Zenon that will allow me to create Alarm Areas dynamically from VSTA code?
    If I cannot directly create the Alarm Areas in VSTA, is there a method available that will allow me to import the Alarm Area information from an XML file similar to the variable import from XML.
    e.g
    ActiveDocument.Variables().Import("Variables.xml");
    Mitch.
    881
    Default Re: dynamically create Alarm Areas
    check out this thread: http://www.copadata.com/forums/showthread.php?t=454
    The zenon API interface offers the same possibilities regardless which programming language is used. So you simply have to translate the VBA code to C#/VB.NET.
  1. Create database IMM
    By dvangenderen in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 17th October 2011, 12:31
  2. Status variable for alarm areas
    By hicom in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 24th February 2009, 09:56
  3. Alarm Status Line and Alarm List
    By tomaslipa in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
  4. Dynamically changing alarm descriptions
    By mattsd in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 9th November 2007, 10:44
