Thread: Where can I find the firmware?
    105
    Default Where can I find the firmware?
    Where can I find the firmware to download? and how do I download it?
    105
    Default Re: Where can I find the firmware?
    If you have got the DVD 'zenon Science Package for LEGO DVD' from COPA-DATA you have allmost everything you need.
    In there you find the step by step manual to start.
    In detail you find in the DVD the folder:
    DVDdrive:\Information\ - here you find the step by step manual
    DVDdrive:\Additional_Software\FIRMWARE\ - In this folder the firmware file is located
    DVDdrive:\Additional_Software\USB_DRIVER\ - The driver (for windows) for connecting the controller via USB
    For the download of the firmware you need the program that is delivered with the LEGO brick set 8547. With that LEGO MINDSTORMS NXT 2.0 software and the step by step manual it is very easy to download the firmware to your mindstorms controller.
    The step by step manual is also attached to this post.
    Attached Thumbnails Attached Thumbnails zenonSciencePackageforLEGO.pdf
    105
    The firmware is also included in the downloadable add-On file Package.
    see this post
    Have Fun,
    Markus
    105
    For the LEGO EV3 there is no special firmware needed.
    The straton Runtime can be found on the zenon Science package DVD in Additional Files.
    --> DVD:\AdditionalSoftware\Science Package - Firmware\EV3
    Markus
  1. How variable get or find COA and IOA
    By aleks2 in forum VBA
    Last Post: 18th July 2013, 12:43
  2. Replies: 0
    Last Post: 14th November 2007, 13:39
  3. CE doesn't find runtime-server
    Last Post: 28th August 2007, 11:44
