Thread: Compatibility with Windows Server 2008 R2 64bits?
    23.04.2009
    56
    Default Compatibility with Windows Server 2008 R2 64bits?
    Recently we try to immigrate our ZenOn projet from Windows XP 32bits to Windows Server 2008 R2 64bits. But we met some problems, especially for Message Control function.
    After the installation of the voice message modem and the SMS modem under Windows Server 2008, I can not find these two modems in ZenOn Editeur.. This is not the case under Windows XP system.
    Have you done any compatibility test for the ZenOn under Windows Server 2008 R2 64bits? Do you have any idea about my problem? Thank you very much.
    Default Re: Compatibility with Windows Server 2008 R2 64bits?
    yes we have successfully tested with Windows Server 2008 R2 x64 and had no problems.
    Of course the used modems have to be supported by the Operating System and there have to be appropriate drivers.
    Which modem(s) are you using?
    23.04.2009
    56
    Thank you bernhardf for your reply.
    What we used, is "Longshine LCS-8156A, 56k V.92, USB from Longshine". This is in your recommendation list:
    http://www.copadata.com/forums/showthread.php?t=57
    By the way, which modem you used during your test with Windows Server 2008 R2 x64?
    Quote Originally Posted by bernhardf View Post
  1. Compatibility with Win2008 Server
    By michaelagito in forum Engineering Studio & Service Engine
    Last Post: 7th September 2009, 10:43
  2. character map on windows server 2008
    Last Post: 23rd April 2009, 14:14
  3. Using distributed engineering on PCs with Windows XP or Windows Vista
    Last Post: 31st January 2008, 10:34
