Thread: how to change driver in runtime
    victoria Gast
    Default how to change driver in runtime
    hi!
    i wanna change the driver (such as IEC 101)of 400 variable to intern variable in runtime
    how can i do it?
    thanks alot
    Default Re: how to change driver in runtime
    can you please precise your question?
    What are you trying to achive?
    It is not possible to change the driver of a variable during Runtime operation with VBA.
    If you want to map the driver variables to internal variables you could use allocations, but as I do not know what your target is, it is hard to answer this question.
    victoria Gast
    sure
    thank for your answer
    i some times need disconnect some variables from the driver that assign to them and map them to internal mode. i wanna gain this aim with some tools like a button as i click, the driver of variable change to internal
    i know with context menu i can do some choices but i need this sequence happen spontaneously just with a click or some thing like this
    880
    If you want to "deactivate" some variables (because do to maintance or so) you can switch the variable to the AlternateValue Status
    -> check out the help documentation at: Manual -> Status processing -> Status bits -> Alternative value (ALT_VAL)
    ... as mentioned there you have several possibilities to de-/activate variables from being polled via the driver.
    Quote Originally Posted by victoria View Post
    hi!
    how can i do it?
    thanks alot
    As Herbert already mentioned, you can use status processing, to stop variables from communicating to the PLC and use an internal value instead.
    Another possibility is to use the zenon function "driver commands" and switch the complete driver to simulation mode. This however would affect all variables from this driver, where as with status processing you can decide on a per-variable basis.
    Rgds,
  1. How to change ComboBox Entires with VBA
    By matthias.zoellner in forum VBA
    Last Post: 8th June 2011, 10:34
  2. is there a way to change the export path in the RT(CEL
    Last Post: 10th December 2009, 19:20
  3. Change the Ip Address in Zenon 5.5
    By sikenga in forum zenon Network
    Last Post: 9th June 2009, 13:09
  4. Change variable status
    By brada in forum VBA
  5. Replies: 0
    Last Post: 21st August 2007, 08:15
