Thread: Load on CPU
    04.09.2009
    84
    Default Load on CPU
    Hi Support,
    Graphics can be made either by linking the images (GIF, Bmp, ...etc) or making the same images by using the built in drawing tools in Zenon Editor. If we are talking about more than 30 pictures handled by the Runtime for any general Project, which option puts more load on CPU, using the external images or making our own?
    Thanks.
    Default Re: Load on CPU
    One thing I am aware of that causes a higher CPU load, is animated GIF files. If you use many complex anmiated GIF files in a screen, this causes a higher CPU load.
    However this is not something specific to the zenon runtime, you have the same effect when showing these animated GIF files e.g. in Internet Explorer.
    Other than that, you probably wouldn't really notice the difference between e.g. a .bmp graphic or a vector graphic, when you are not using super high resolution .bmp files.
    Do your concerns involve a particular issue? Or why do you ask?
    04.09.2009
    84
    Hi Mark,
    No, I am not facing any specific issue related to this subject, but just wanted to have an idea that if I want to go for the most optimized solution, should I take the headache of creating vector graphics or the ready made graphic images would be fine
  1. Replies: 3
    Last Post: 11th October 2011, 23:24
  2. display the load changing
    Last Post: 1st February 2010, 00:35
