Showing results 1 to 7 of 7
Thread: Auto Scaling problem
    30.12.2008
    4
    Default Auto Scaling problem
    I am new in this forum
    I work on a Zenon supervision project
    I have a question concerning the implementation of the Auto Scaling of curves in vba,
    I would like to retrieve the min and max date in the curve display before I can look in the archives the maximum value of the variable,
    Here are a few lines of code that I do,
    Thank you in advance for your reply,
    //-------------------------------------------vba code----------------------------------------
    Public Sub autoSCale()
    Dim obFctTrend As RtFunction
    Dim strDynProp As String
    Dim iCurves As Integer
    dim vStart, vEnd as Date
    Set obFctTrend = thisproject.RtFunctions.Item("Courbe")
    For iCurves = 0 To obFctTrend.DynProperties("PictFilter.Curve[-1]")
    strDynProp = "PictFilter.Curve[" & iCurves & "]"
    If InStr(1, "Empty", obFctTrend.DynProperties(strDynProp & ".VarInfo.VarName")) = 0 Then
    'She always give me the date value 01/01/1970 01:00:00
    vStart = obFctTrend.DynProperties("PictFilter.TimeAxe.TimeFilter.ARVTime1")
    'She always give me the date value 01/01/1970 02:00:00
    EndDate = obFctTrend.DynProperties("PictFilter.TimeAxe.TimeFilter.ARVTime2")
    'Search in the archives the min and max of the variable of the curve between the dates vStart and EndDate
    updateMinMax (obFctTrend.DynProperties(strDynProp & ".VarInfo.VarName"), vStart, EndDate)
    obFctTrend.DynProperties(strDynProp & ".XAxe.Scale.ScaleTop") = max
    obFctTrend.DynProperties(strDynProp & ".XAxe.Scale.ScaleBotton") = min
    obFctTrend.Start
    End If
    Next iCurves
    Default Re: Auto Scaling problem
    Hi, zenon
    I don't know if it is still relevant, but perhaps you could phrase your question?
    I'm not sure what your question or your issue is. Feel free to upload a sample project backup, if that makes it easier to explain.
    30.12.2008
    4
    Hello, thanks for your response,
    what i want is juste how to read the displayed trend values from vba.
    coordially
    880
    It is not possible to read the displayed archive values out of the ETM via VBA
    -> since zenon >= 6.50 it is possible to export the shown data in the ETM to i.e. a text file
    If you want to implement a autoscaling on the y-axis (based on min/max of the archived values) you would have to do something like this:
    - evaluate via vba the min/max values for the given timespan directly on the archive itself (not ETM)
    - modify the picture switch function to the ETM (adapt min/max of the y-axis)
    - execute modified function
    As far as i know there exists already the requirement for this feature to have this available in a future version of zenon....
    30.12.2008
    4
    Yes, I taught both solutions before I post my question, but I had some problems.
    First, when using the export function of Zenon into text file, it does not export the displayed values in the curves, but all the variables values.
    Second, and we suppose that all the variables must be archived (witch is not the case for all variables of our project).
    How I can read the min max time-Span in the displayed curves from vba.
    Best regards
    880
    again:
    Have a look into the help documentation (Programming Interface -> Object Model). Here you can find example how to get values out of an archive
    30.12.2008
    4
    Hello, thank you again for your response
    Here attached a sample program that I tried to do for autoscaling.
    cordially
  1. Auto Logoff
    By yara in forum zenon Service Engine Supervisor
    Last Post: 31st July 2011, 23:29
  2. User managment Problem, Snapshot relativ Problem
    By jusufs in forum zenon Service Engine Supervisor
    Last Post: 13th September 2010, 23:06
  3. y-scaling trendelement
    By affoltep in forum zenon Service Engine Supervisor
    Last Post: 22nd July 2009, 13:38
  4. Auto start runtime when windows starts
    By craigdouglas in forum zenon Service Engine Supervisor
    Last Post: 12th February 2009, 18:14
