Showing results 1 to 1 of 1
Thread: Message-Box "VBA Error 1" appears at RT start
    879
    Default Message-Box "VBA Error 1" appears at RT start
    When I start zenOn Runtime (client, server, or WEB client,…), I always get an errormessage called "VBA Error 1". What does it mean?
    "VBA Error 1" means, that the VBA file used by the zenOn Rutime is currently set to "read only", or exclusively opened by another program.
    Solution: Make sure that the file is not "read-only", or no other program is accessing it. If that doesn´t work either, delete your runtimefiles and create/tranfer them again.
    Edit:
    Another reason for this errormessage can be the too less granted rights by windows user administration (also check if all zenOn processes and services are running with the same user)
    Last edited by herberto : 18th October 2007 at 09:33 Reason: User rights issue added
  1. Close "Web-Client" window automatically
    By herberto in forum zenon Network
    Last Post: 25th May 2016, 10:42
  2. Replies: 2
  3. Replies: 0
    Last Post: 18th September 2007, 14:01
  4. Replies: 0
    Last Post: 20th August 2007, 14:14
  5. function "Export Data" on Windows CE
    Last Post: 20th August 2007, 07:01
