Thread: 6.20 SP4 MSDE MSSQL Installation not possible
    27.08.2008
    50
    Default 6.20 SP4 MSDE MSSQL Installation not possible
    Hello!
    I am trying to install a 6.20 SP4 Editor on a fresh Windows XP SP2 Installation.
    But the Installation of the MSDE is not able to suceed.
    2011-09-22 12:07:58.42 server Microsoft SQL Server 2000 - 8.00.2039 (Intel X86)
    May 3 2005 23:18:38
    Copyright (c) 1988-2003 Microsoft Corporation
    Desktop Engine on Windows NT 5.1 (Build 2600: Service Pack 2)
    2011-09-22 12:07:58.42 server Copyright (C) 1988-2002 Microsoft Corporation.
    2011-09-22 12:07:58.42 server All rights reserved.
    2011-09-22 12:07:58.42 server Server Process ID is 2580.
    2011-09-22 12:07:58.42 server Logging SQL Server messages in file 'C:\Program Files\Microsoft SQL Server\MSSQL$ZENON\LOG\ERRORLOG'.
    2011-09-22 12:07:58.42 server SQL Server is starting at priority class 'normal'(2 CPUs detected).
    2011-09-22 12:07:58.87 server SQL Server configured for thread mode processing.
    2011-09-22 12:07:58.89 server Using dynamic lock allocation. [500] Lock Blocks, [1000] Lock Owner Blocks.
    2011-09-22 12:07:58.89 spid3 Warning ******************
    2011-09-22 12:07:58.89 spid3 SQL Server started in single user mode. Updates allowed to system catalogs.
    2011-09-22 12:07:58.92 spid3 Starting up database 'master'.
    2011-09-22 12:07:59.04 server Using 'SSNETLIB.DLL' version '8.0.2039'.
    2011-09-22 12:07:59.04 spid5 Starting up database 'model'.
    2011-09-22 12:07:59.04 server SQL server listening on 10.17.124.27: 1040.
    2011-09-22 12:07:59.04 server SQL server listening on 127.0.0.1: 1040.
    2011-09-22 12:07:59.04 server SQL server listening on TCP, Shared Memory, Named Pipes.
    2011-09-22 12:07:59.04 server SQL Server is ready for client connections
    2011-09-22 12:07:59.06 spid3 Server name is 'WCS-IPOINT\ZENON'.
    2011-09-22 12:07:59.06 spid3 Skipping startup of clean database id 5
    2011-09-22 12:07:59.06 spid3 Skipping startup of clean database id 6
    2011-09-22 12:07:59.06 spid3 Starting up database 'msdb'.
    2011-09-22 12:07:59.15 spid5 Clearing tempdb database.
    2011-09-22 12:07:59.51 spid5 Starting up database 'tempdb'.
    2011-09-22 12:07:59.54 spid3 Recovery complete.
    2011-09-22 12:07:59.54 spid3 SQL global counter collection task is created.
    2011-09-22 12:07:59.54 spid3 Warning: override, autoexec procedures skipped.
    2011-09-22 12:10:03.59 spid3 SQL Server is terminating due to 'stop' request from Service Control Manager.
    Default Re: 6.20 SP4 MSDE MSSQL Installation not possible
    I cannot see anything immediately from this file, where it might go wrong. There should however be more logfiles about the installation of the SQL server itself.
    Here are a few other things you can try:
    - install the latest Windows updates / service pack
    - manually install MS XML
    - disable anti-virus software during installation
    If you don't need the editor on this PC, consider installing the runtime only. The MSDE is not required for the runtime.
  1. Replies: 0
  2. Silent installation of Zenon
    By cleitgeb in forum Editor and Runtime Setup
    Last Post: 1st December 2008, 15:26
  3. Installation on Touch Screen using DOM
    By tauhien in forum Editor and Runtime Setup
    Last Post: 26th September 2008, 02:56
  4. Please Guide me about New Installation??
    By majidhanif in forum zenon Operator
    Last Post: 19th November 2007, 13:00
