Thread: Get milliseconds information from CelItem
    ferran Gast
    Default Get milliseconds information from CelItem
    Hello all,
    Does anyone know how to get the milliseconds information from a CelItem object?
    I'm getting the user interaction to the "events list" through the "CelListSelectionChanged(ByVal obItem As ICelItem)" callback. It works fine. But I can't find any indication of the milliseconds value of the event appearance (you can get the CelItem.Time property that gives you a Date object, with seconds granularity)
    Thanks to everybody.
    Default Re: Get milliseconds information from CelItem
    VB does not support milliseconds when converting the Zenon timestamp, so you need to calculate them by yourself (from the Zenon double variable).
    you can use the following code:
    Private Sub zCEL_CelItemAdded(ByVal obItem As ICelItem)
        'when a new entry was generated....
        'Debug.Print "CelItemAdded - " & obItem.Text
         Dim zText As Variable
         Dim zTime As Variable
         Dim myTime As Double
         Dim myTimeString As String
         Set zText = thisProject.Variables.Item("CEL_TEXT")
         Set zTime = thisProject.Variables.Item("CEL_TIME")
         'get the ms
         myTime = obItem.Time
         myTime = myTime * 86400 * 1000
         myTimeString = CStr(myTime)
         myTimeString = Right(myTimeString, 3)
         zText.Value = CStr(obItem.Text)
         zTime.Value = CStr(obItem.Time) & "." & myTimeString
    ferran Gast
    Thank you very much bernhardf, it works.
    ferran Gast
    If anybody else founds this Thread interesting, one last comment:
    It seems that the automatic conversion to VBA Date type rounds up the seconds if milliseconds > 500ms: If the date is, say, "2011/1/1 12:23:45.678", then the date when you call "obItem.Time" will return "2011/1/1 12:23:46".
    I used the following code to substract one second when ms >= 500ms:
    Private Sub zCEL_CelListSelectionChanged(ByVal obItem As ICelItem)
        Dim itemDate As Date
        Dim milliseconds As Integer
        ' Get the ms
        milliseconds = Int(Right(CStr(obItem.Time * 86400 * 1000), 3))
        ' Calculate seconds (avoid roundup)
        itemDate = obItem.Time
        If milliseconds >= 500 Then ' seconds have been roundup by VBA...
            itemDate = DateAdd("s", -1, itemDate) ' substract one second
        End If
    end sub
    Hope it helps somebody else.
  1. Archives (RT) - Read batch information
    By herberto in forum VBA
    Last Post: 25th July 2011, 14:09
  2. CEL Entries in Milliseconds
    Last Post: 7th April 2010, 08:49
  3. Replies: 0
    Last Post: 11th March 2010, 16:04
  4. Information Unlimited 16 - Sample
    By robertf in forum VBA
    Last Post: 28th November 2008, 13:34
  5. We need further information about web server on zenOn...
    By nuno_duarte in forum zenon Network
    Last Post: 18th March 2008, 18:05
