Thread: reset of Drag indicator
    26.11.2009
    59
    Default reset of Drag indicator
    Is there any way to reset the Drag Indicator (min/max) of Universal slider in Runtime manually?
    Currently It has Auto reset function and will be reset after definite time.
    How it will be reset if I do not activate auto reset function?
    thanks
    Default Re: reset of Drag indicator
    you can reset the min / max by double-clicking the element
    26.11.2009
    59
    Hi
    There is another problem in my project regarding color of universal slider in RT. Please find its properties as attached screen shots.
    I expect according its configuration and screen in editor environment, the color of bar be blue but in RT it is red for all values. Also “use limit color” is unchecked.
    Could you please have suggestion for me in this matter?
    Attached Thumbnails Attached Thumbnails Slider property 1.JPG   Slider property 2.JPG   Slider property.GIF
    Just judging from the screenshots, I would think they would be blue. I cannot say anything more from just the screenshots.
    If you need someone to have a look into this, I suggest posting a small sample project here, or contact your local support
  1. Reset of counter variables
    By roberto1978 in forum VBA
    Last Post: 20th June 2011, 10:40
  2. Reset Flashing
    By tanveerali in forum zenon Service Engine Supervisor
    Last Post: 17th May 2011, 00:15
  3. Set Value via Drag&Drop (VBA)
    By herberto in forum VBA
    Last Post: 4th December 2008, 13:51
