Thread: Priamry and Secondary Server configuration
    Default Priamry and Secondary Server configuration
    Dear Support,
    I am trying to configure Primary and secondary servers can you guide to the proper procedure to do so.
    Secondly I have 5 different projects and I want to link them all in a single project so that during runtime all of them are available simultaneously.
    Default Re: Priamry and Secondary Server configuration
    With multiple projects, you normally have one integration project, as the start project, and one or more sub-projects.
    Using Drag&Drop in the project tree, you can create a multi-hierarchical project structure below your integration project.
    Setting up redundancy with server and standby server is as easy as activating a checkbox, and specifying the server name and standby server name. (the computer name, not the IP-Address)
    Very convenient for multiple projects and multiple PCs, is the topology view in the zenon editor, to quickly transport runtime files to all PCs, and define which PC should start which project.
  1. facePlate configuration
    By ansab.tp in forum zenon Service Engine Supervisor
    Last Post: 25th January 2012, 00:47
  2. Server & Client monitor configuration
    By roberto1978 in forum zenon Network
    Last Post: 10th January 2011, 23:19
  3. SNMP-Configuration
    By rolindo in forum zenon Network
    Last Post: 11th December 2009, 08:36
  4. Configuration of Alarm in Zenon Editor
    By bmcbrita in forum zenon Service Engine Supervisor
    Last Post: 6th August 2009, 09:16
  5. Replies: 0
    Last Post: 20th August 2007, 16:57
