Thread: Program access to structure datatype variables
    Default Program access to structure datatype variables
    Guten Tag!
    We have a lot of structure datatype variables in our projects and wish to use their Identification field in our VBA or C# programs. When we tryed to access this variables by .Variables().Items(StructureTypeVarName) we received "null" as result.
    Is there some way to program access to at least Identification field of such variables?
    24.07.2008
    89
    Default AW: Program access to structure datatype variables
    it worked for me when I wrote the variables like they are displayed in zenon:
    STRUC[1], STRUC[2]...
    thisProject.Variables.Item("STRUC[1]").Tagname 'Tagname = Identification field
    thisProject.Variables.Item("STRUC[1]").Unit
    Konstantin
    Default Re: Program access to structure datatype variables
    konstantinf
    I don't understand where in zenon complex variables are displayed in such way.
    In other words, I have complex variables which after xml export are looked like this:
    839
    220.1AT.Q.PlakatInf
    ОРУ 220кВ АТ-1 Выключатель
    TRUE
    FALSE
    TRUE
    33
    FALSE
    TRUE
    I cannot get programmable access to such variable by it's name, 220.1AT.Q.PlakatInf, code line like this:
    zenOn.Variable var1 = ObProjectRT.Variables().Item("220.1AT.Q.PlakatInf");
    always returns null, so access to var1 properties is disabled.
    What I do wrong?
  1. Replies: 6
  2. Replies: 1
    Last Post: 19th May 2011, 07:51
  3. Structure varible using OPC Client V2-0
    By bsneddon in forum Drivers
    Last Post: 21st April 2011, 23:49
  4. ext. program start in CE5.0 system
    By rgnos in forum zenon Service Engine Operator
    Last Post: 2nd August 2009, 22:28
