Thread: Some variable's properties to be filled with the archived value of a variable in a report sheet
    25.04.2011
    10
    Default Some variable's properties to be filled with the archived value of a variable in a report sheet
    In a report sheet we need to have a column of the value of an archived variable. Meanwhile we need the next columns to be filled with “unit” and the “limit text” of this archived variable.
    I mean when an archived value is logged in the report sheet, the next columns indicates the “unit” and “limit text”.
    I know how to make the function of “value” column, but don’t know how to do it for “unit” and the “limit text”.
    Thank you.
    27.06.2011
    95
    Default AW: Some variable's properties to be filled with the archived value of a variable in a report sheet
    Hello Hamid,
    only variable values, timestamps and status are stored in an archive. Therefor it is not possible to display unit and limit text of archive values.
    kind regards
  1. Replies: 1
  2. Replies: 9
  3. Archived Trends
    Last Post: 20th March 2011, 23:20
  4. Problem with archived trend data
    By k_r_mehta in forum zenon Supervisor
    Last Post: 13th December 2010, 13:23
  5. Copy from variable to other variable
    By cyrilfeasy in forum zenon Supervisor
    Last Post: 5th November 2009, 17:25
