Page 1 of 2 1 2 LastLast
Showing results 1 to 10 of 12
Thread: create project
    14.12.2010
    25
    Default create project
    when i restore project or make new project error window appear on screen .screen shot is attached
    Default Re: create project
    it seems that the zenDBSrv.exe is not running.
    Please check in the Taskmanager if the zenDBSrv.exe process is running.
    If not, close the Editor and re-register your zenon version with the startup tool and check afterwards if the zenDBSrv.exe is running.
    Then you should be able to start the Editor and restore/create projects.
    14.12.2010
    25
    Ausrufezeichen Re: create project
    I checked in taskmanager there no file or service with name zenDBSrv.exe. only one service is there name zenadminser.exe is avalible . can you plz guide me how to add this service.
    did you re-register with the Startup Tool, the zenDBSrvshould be started (and if not there should be an Error message).
    Also check the Taskmanager while registering (sometimes the zenDBSrv starts and closes immediately afterwards).
    You can also check if your ZENON_DEV SQL Server instance is running (check in the services.msc).
    you can also try and download the testconnection tool, and check the database connection.
    testconnection
    14.12.2010
    25
    i format my PC and install new window but still i face same problem.when i install zenon the attached message is show after few min . i use i7 with window 7.plz guide me
    From the screenshot it can be seen that there is an issue with the installation of the Microsoft SQL Server 2005 Express on your system.
    Please note, that this is not a general issue, this works OK on other Windows 7 systems with 32 bit and 64 bit.
    Some general things you can try when trying to install zenon:
    - make sure you install all Microsoft Updates available for your system. Please note that it may take several restarts and several checks to install all updates.
    - close all running programs while installing zenon
    - disable anti-virus or internet protection software while installing zenon
    If all this does not help, please contact your local COPA-DATA support. They should be able help you.
    14.12.2010
    25
    before installing zenon i disable firewell and anti vires but problem is still same . i am living in saudi arabia can you send local support phone number.
    For your local COPA-DATA support, you can check out our website, ask your COPA-DATA sales representative, or in doubt, write an e-mail to COPA-DATA international support
    14.12.2010
    25
    I Have 4 Dell laptops i7, 64bits with Window 7 . i am facing same problem with all system that is mention below . Is there any procedure to install zenon in OS window 7 ?
  1. Create Scrollbar
    By brc in forum zenon Supervisor
    Last Post: 27th December 2010, 15:35
  2. Replies: 12
  3. how can be save the project that consist of the sub project?
  4. can't create new project in zenon editor
  5. How to create a new MACRO?
    By matholton in forum VBA
