Showing results 1 to 8 of 8
Thread: Save Alternate Value?
    16.06.2011
    N/A
    43
    Default Save Alternate Value?
    Hi to all
    In Runtime I Have to Switch to alternate value and Modify alternate value. But when reload the Runtime variable Switch to spontaneous value. How can I save alternate value after reload the Runtime?
    Default Re: Save Alternate Value?
    Which driver are you using? And which zenon version, service pack and build?
    Normally when the variable is switched to alternate value, and something is changed and the runtime is reloaded, the variable should keep the alternate value active!
    16.06.2011
    N/A
    43
    Frage Re: Save Alternate Value?
    I am using IEC 61850 driver. My version of Zenon: Zenon 6.51 SP0 Build 0. I am using demo version of Zenon. May be I have to edit properties of Variable?
    16.06.2011
    N/A
    43
    I was installed Build 5 but value don't save.
    879
    Try to activate the driver option "Variable image remanent"
    The option "variable image remanent" indeed saves the variable status and alternate value, also when closing and starting the runtime.
    However after a normal reload of the runtime, the alternate value should still be active even when this setting is not set.
    How do you activate the alternate value? And how do you deactivate it? Is there something in your project that may switch the variable to spontaneous value after a reload? (e.g. in your VBA - project active for example)
    When you try with a new small project, with only one variable in a numerrical value element in the screen, and activate the alternate value through the set value dialog, is this also reset when you reload?
    16.06.2011
    N/A
    43
    Thanks, It really working now.
    16.06.2011
    N/A
    43
    Through the set value dialog.
  1. how can be save the project that consist of the sub project?
  2. switch to the alternate value
    By westbaaam in forum VBA
    Last Post: 29th November 2009, 23:55
  3. HELP: I can not save dbf files in excel!
    Last Post: 12th June 2008, 07:11
