Thread: Driver for Siemens S7-1200
    10.01.2008
    Vimmerby / Sweden
    11
    Default Driver for Siemens S7-1200
    Hello.
    We have a siemens S7-1200 plc we want to communicate with.
    We already have the S7 TCP-IP driver fore some S7 300, is this the same driver for S7-1200?.
    How should we set the TSAP setting?.
    Is it anny other setting we have to change?
    Zenon 6.51
    Regards
    Peter G
    Default Re: Driver for Siemens S7-1200
    Yes, the S7TCP32 driver can be used to communicate to a S7-1200 PLC.
    For the remote TSAP you need to use "02.01" (01 is the CPU location in the rack)
    In Step7 for the data blocks (DB), you need to deactivate the option "only symbolic addressing" in order for the communication to work.
    13.06.2013
    Default Re: Driver for Siemens S7-400
    We have a siemens S7 400 CP 443-1, the problem is i cannot connect zenon 5.50 application. the error is communication disturb when running zenon runtime. is there any settings that i miss or need to be change?
    Which settings should i look for zenon or in simatic net manager?
    thanks and hope you can help me.
    please send me some examples of configuration connecting an application to remote partner.
    30.05.2007
    105
    Hi ric,
    When communicating with a S7-400 system you have different slot numbers for your CPU location.
    depending if you using a (1)single slot power supply or (2)double slot you need to set the remote TSAP to (1) 02.02 or (2) 02.03
    And, please also consult the driver manual.
    Markus
    06.06.2018
    9
    Dear Ric ,
    I want to communicate with Zenon 6.22 SP1 runtime on a PC with S7 300 plc on profinet / Ethernet port .
    Do I need any card like CP 443-1 in order to establish the communication ? or it can be done without any additional card .
    Waiting for the prompt reply !
    Manku
    Quote Originally Posted by ric_5518 View Post
    17.04.2019
    Is the method shared by the members are still useful?
  1. Siemens PLCSim
    By gh_ounie in forum Drivers
    Last Post: 5th September 2014, 20:42
  2. zenon und Siemens MP370 Touch
    By s.koeppe in forum zenon Operator
    Last Post: 26th May 2011, 00:25
  3. Reading "M" bits in Siemens
    By scotttee in forum Drivers
    Last Post: 24th September 2009, 08:45
