Thread: Problem with upgrading the Web-server
    nurul Gast
    Default Problem with upgrading the Web-server
    I'm upgrading the web-server version from 6.50 to 6.51.
    1- At first we just installing the Web-server version without deleting the previous version. Then we change the zenOn version in the global_vars.js setting and after that Start the Web-server. When we start RT from Web-client, there's an error message shows that they couldn't find the alc.mp file.
    2- Then we tried to uninstall the web-server and re-install the program back. But we found out in the folder :\C\Program Files\Copa-Data\zenOn WEB Server,that there's no zenOn folder which consists of global_vars.js and etc.
    We try to install the web-server in other machine. The folder is there! I do not know what when wrong. Do you have any clue?
    nurul Gast
    Default Re: Problem with upgrading the Web-server
    Hi Guys,
    I solve it. Thanks for the support
    For your first issue with the error regarding "alc.cmp" it may be of help to empty your %temp% directory to force the local webclient to get all the files from the server.
    For your second issue, on 64 bit systems, the folder for the webserver is "C:\Program Files (x86)" instead of "program files".
  1. Replies: 3
    Last Post: 25th June 2011, 09:51
  2. Problem with server redundants
    By mohamad.kasaeifard in forum zenon Network
    Last Post: 23rd May 2011, 00:16
  3. Problem mit Server Client Netzwerk bei CE Geräten
    By nsc2001 in forum zenon Operator
    Last Post: 26th November 2010, 07:55
  4. Client / Server problem
    By stevegrice in forum zenon Network
    Last Post: 9th December 2009, 01:58
  5. Archive Server Problem
    By rloureiro in forum zenon Supervisor
    Last Post: 28th August 2008, 14:56
