Thread: Extended Trend HD Depth
    04.09.2009
    84
    Default Extended Trend HD Depth
    Hi Support,
    Can you explain the term 'HD Depth' that is shown when we configure the Extended Trends Picture for the very first time? What exactly is the meaning of the Numerical figure that is shown as HD Depth?
    Thanks.
    Default Re: Extended Trend HD Depth
    can you attach a screenshot, to see which parameter you are exactly talking about?
    Basically:
    With variables a harddisk storage can be set, which is a kind of ringbuffer, and the HD depth means the amount of values to be stored. E.g. a depth of 10 means that the 11th value removes the very first from the ringbuffer, it also means that for the dynamic element trend or the ETM a curve can be drawn on the basis of 10 values.
    04.09.2009
    84
    Thanks Wolfgang, I have got a clue about what does it mean after reading your explanation.
    Regards.
    the suggested HD depth at the screen switch function to the extended trend is a combination between the time period of the x-axis of the trend, and the refresh rate of the trend.
    e.g. when setting a time period of 5 minutes, and a refresh rate of 1 second, the suggested HD depth is 300 values (1 value per second for 5 minutes).
    When acknowledged, the HD depth will then be taken over at the variable properties (hard disk data storage settings) itself.
  1. Trend details
    By bojan in forum zenon Supervisor
    Last Post: 30th March 2011, 00:00
  2. Extended trend module question
    Last Post: 4th August 2009, 23:58
  3. Extended Trends Problem
    By douglasm in forum zenon Operator
    Last Post: 26th June 2009, 10:15
