Thread: Variable setting
    whitetaru Gast
    Default Variable setting
    Lets say i have Variables, A,B,C,D and E. All are binary type.
    How do i set A=1, when B=C=D=E=1?
    How do i set A=0, when B=C=D=E=0?
    Warmest Regards
    Whitetaru
    Default Re: Variable setting
    You can use a variable from the mathematics driver.
    This driver is created by default and allows you to make such logical calculations based on other variables.
    Simply create a new boolean formula variable of the mathematics driver, add the B, C, D and E variables to the formula in the calculation. The formula would be X01 AND X02 AND X03 AND X04 (the value of the mathematics variable "a" would be "1" when the condition is true, and "0" when the condition in the formula is not met)
    whitetaru Gast
    Thanks alot
  1. Setting the clock time element
    By douglasm in forum zenon Supervisor
    Last Post: 26th February 2010, 23:59
  2. Replies: 2
    Last Post: 4th December 2009, 10:08
  3. "variable image remanent" setting is not saved
