Thread: Runtime Error
    04.09.2009
    84
    Default Runtime Error
    Hi Support,
    I have a Project on Zenon Energy Edition 6.22. When I put the runtime files in another pc and install the Zenon Runtime and try to run this project by specifying its correct path, I receive an error saying 'Error in loading IEC850 Module' (Screenshot attached). Process Variables are 61850 variables and they are set in simulation mode.
    Default Re: Runtime Error
    Perhaps XML Lite is missing on this PC? The IEC850 driver requires XML Lite to be installed.
    This can happen on Windows XP, when only Internet Explorer 6 is installed. Updating to Internet Explorer 7 also installs XML Lite. Alternatively you can download and install XML Lite from Microsoft seperately.
    04.09.2009
    84
    It definitely was XML Lite, I just figured it out early in the morning
    I am impressed how you exactly reached the right solution, good work Mark!
    By douglasm in forum VSTA
  2. Replies: 0
    Last Post: 7th August 2008, 11:57
  3. Replies: 1
  4. Error message at Runtime Startup
    By martinw in forum zenon Supervisor
    Last Post: 20th August 2007, 08:07
  5. error message when starting the Runtime
