Thread: Make a copy of a project.
    takarlsson Gast
    Default Make a copy of a project.
    Hej
    We have 3 projects in a Windows XP with Zenon 6.22.
    Each of the project is also downloaded to a panel with Windows CE.
    One of the project is to be duplicated. The project contain two object, M1 and M2. In the new project the name is to be M3 and M4.
    If I make a copy of the project, how do I rename all signals, pictures, functions… from *M1* to *M3* and *M2* to *M4*?
    Any suggestion?
    regards
    Tommy
    Default Re: Make a copy of a project.
    it depends on what you want to rename.
    Variables, Screens, Frames, Functions for example you can rename by simply using the "Replace text in selected column" functionality in the Detailview.
    As a picture tells more then thousand words.
Name:	2011-04-07 15h55_09.jpg
    takarlsson Gast
    Thanks, it worked. Links was updated with the new names.
    How do I rename scripts?
    Regards
    Tommy
    takarlsson Gast
    Found another bug in Zenon. It is not possible to rename scripts or?
    Regards
    Tommy
    in zenon 6.22, the script is referenced by the name at the script execute function. When you rename a script, you also need to change the "script execute" function to the new name.
    In 6.50 or 6.51 this has been changed, and now the script is referenced by it's ID. This means that when you rename the script, the script name automatically changes at the script execute function.
    What you could try, is XML export the script execute functions in your copied project, open the XML file with an XML editor, or notepad, and use "search / replace" to change the name of the scripts according to your new script names, and import the functions again.
  1. Copy recipe to a CE panel.
    By takarlsson in forum zenon Operator
    Last Post: 5th April 2011, 13:18
  2. Replies: 12
  3. how can be save the project that consist of the sub project?
  4. Template copy across projects
    By mvj in forum VBA
    Last Post: 10th February 2010, 17:18
  5. copy recipes
    Last Post: 11th May 2009, 05:28
